Total Noob, Wanting to Learn
  • 4
I'm a noob who has no idea what I'm doing, but I'm looking to learn. Currently I'm running a Sony Mex-n5100bt for the deck
Skar Audio SDR-15 dvc 2ohm powered by a Rockford Punch p650.2
Two Rockford r2d2 12"s powered by an Alpine mrv-m500
The 12s are in a sealed enclosure, as well as the 15". I bought the 12s a month ago and everything was fine till yesterday when one of them blew.
 Is it possible to find a ported enclosure for 2 12's with subs for $300? I don't want to get the bottom of the barrel equipment anymore, but I definitely can't afford the best.
$300 is pushing the limits for my budget, so I'd even be cool with something used. I can't buy right away, I'm just looking at my options ahead of time. It could be about two weeks from now.
Why even buy more equipment?
Seems to me that you've got some space available if you got 3 sealed enclosures and mixing drivers/sizes is never a good idea.
I'd recommend using what you got to start and re-enclosing that 15 in a ported box with the punch amp.
Maybe selling the surviving 12 and alpine, buying some wood and joining the ranks of DIY enthusiasts who have actually learned how to build their own enclosure.
The result MIGHT surprise you.
Welcome to the forum... lotsa great guidance/advice on here.
Good luck
x2, i wouldnt get new gear.  id build a box for the 15" or buy one and run it only.  i wouldnt run the 12" with it.  no need
Cool. I'm ordering a ported 15 box this week and ditching the 12s. Can't wait to hear the difference.
Mate, if possible don't use ported and sealed subwoofer box at any one time in the same vehicle.
Cool. Thank you. I wasn't planning on it. I already took the 12s out so now it's just my 15 currently sealed. As soon as the ported box gets here I'll be switching boxes.
Nice move!  With ported enclosure, you get more efficiency so you can turn your amplifier gain down to get the same level of bass you got with a sealed enclosure.  Let us know how you go once you get the new box and give it a run!  Awesome mate!  For me, I cannot go past infinite baffle install. I just love the smooth roll off and my boot space!
I have zero experience running one of those, a little replacing them with a lower tuned enclosure but give it a shot... I think you'll see an improvement in output just not be able to dig under 30hz super well.
That SDR-15 might surprise you in a lower tuned box, If you do switch out eventually and if you do change I feel that Diy is the way to go (It'll save you a ton)... let us know how it works out and enjoy.
Just set-up your signal and filters correctly and you'll most likely be pleased.
So I bought a prefabricated ported enclosure for the 15" and that's the only sub I'm running. It hits harder than the 12s and 15 combined when everything was sealed. Now it's just the 15 ported. I also installed a passive eq which is extremely convenient since my musical tastes vary. And I'm running an amp for the mids. My throat almost tightens up depending on what I'm listening to.
I'm glad some advice was taken eagerly and happy it worked out for you... if you ever want better lows (deeper/lower) try an actual custom enclosure tuned and configured for your vehicle/music tastes.
You'll most likely see an improvement over any Qbomb prefab.
Thanks! It may never have made it to U.S. retail. Actually, I highly doubt it! They have diversified their product line now as can be seen on...
The next time it happens check the voltage directly at the Boss radio. If it has 12v on both the red and yellow wires and the black wire is...
632
As long as you don't run through (or in parallel with) the vehicle's factory wiring you'll be fine.
If I was set on using what you have: I would get a head unit that will play 40-50w RMS x 4. Use that for your 3.5s and 4 x 10s, or get a small...
shredder2
SlugButter
    May 4, 2024
slater
    May 2, 2024
