2 orion hcca 152 15s
  • 3
If you run one amp its gotta be half ohm or 2 ohms. You could run 2 amps @ 1ohm each or strapped.
Maybe keep it in the family an Orion HCCA 3k (amazing amp) @ half ohm? Do you know what your rising to?
Better have strongggg electrical for that.
The newer v2 5k Orion amps are rated at 12.6v like 3700watts at 2ohm and at 14 to 14.5 it should reach 4000 to 5000 at 2ohm load.
Ive seen so many amps done this way over the years. Especially ones that had the Molex plugs and a couple others
9
673
I ran the Orion for about a year, then I bought the Taramps when I though the Orion broke. I found a knick in the Orion bass knob that was causing...
Ive had to install a 40 amp relay on the remote due to Popping issues on one my older Eclipse HUs, That ended up solving my popping issue. One...
I have created a post with all related information regarding the build under this link: https://www.caraudio.com/threads/2000-camry-build.614208/
50
3K
Matt Ryan Robertson
CarAudio.com Newbie
Matt Ryan Robertson
Dragonsyph
Mr FaceCaser
    Apr 26, 2024
Doxquzme
    Apr 26, 2024
Latest topics
