Can I Split a 1/0 Gauge Power Wire into Two Different Gauges? 4 & 8??
  • 3
dnorth2018
CarAudio.com Newbie
I have one amp that recommends using a 4 gauge power wire and ground (Alpine PDX-F4), and another smaller amp that i would prefer to use 8 gauge power wire on.
Can I split a 1/0 gauge power wire into a 4 gauge and an 8 gauge wire? If so can I use the 1/0 to 4 distribution block and just use a smaller 8 gauge wire in one of the output screw holes? Or how should I do it?
Also, will a large power wire like a 1/0 gauge cause more of a drain on the car's battery or alternator than a 4 or 8 gauge wire would? My current car has a weak factory alternator/battery setup, so I'm concerned about using the 1/0 gauge power wire for that reason.
And finally, is it really important to use the manufacturer's recommended 4 gauge power and ground wires on the Alpine PDX-F4, or would 8 gauge be fine?
Thanks
Yes. You can find D blocks with 4 and 8 gauge outputs.
No larger wire will not cause more draw.
Pretty important to use the correct size wire. Don't want to draw too much amperage and cause a fire because the 8 gauge wire couldn't handle the amperage.
Thanks for the response, I should have searched for D blocks before posting. Looking now.
Nope, just purchased and received it for my brothers "74" Ford Currier truck resto build. Small 4 cahnnel taramps and a set of nice 6.5" Pioneer Z...
12
That nvx wire is good stuff...I bought a 1/0 ofc kit...it's easy to work with
19
3K
dnorth2018
CarAudio.com Newbie
dnorth2018
n2audio
Chris Gerrish
    Apr 25, 2024
Chris Gerrish
    Apr 25, 2024
Latest topics
