Single Sundown Sa12 rev 3
Nathanbr11
Alright guys I've been contemplating this build for awhile and finally broke down and decided to seek some advice. I currently have the sub but I'm needing to build a box. (Not the first box I've built) I'm just looking to step it up a little with this one. I have a 98 c1500 ext cab so it'll be in the back but I'm looking at getting either a skar 1500 or 2000 watt amp as an upgrade from my current kenwood 800. I'm thinking just a ported box with a kerf port (going to be using 3/4" mdf) but my main concern is tuning and accounting for the over powering. It's going to be mostly a daily bumper but would like to see what numbers it can pull. Thanks in advance.
Edit: I know its rated for 750rms but we all know they're WAY under rated so I'm also curious how it would do if 2000 watts. Not necessarily worried if I blow it eventually because that's just a good excuse for an upgrade!
Sounds like you need new coils. My Explorer with three 15's, appropriate birch box, fully sound-deadened interior, and a boat behind it does not...
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
405
669
Nathanbr11
Nathanbr11
poolman966554
Brendon Jenness
    May 8, 2024
    May 8, 2024
