9 wire vs running new wire
MattinMO
So I don’t even have it yet but I’m going to be buying my father in laws ‘13 Sentra it has factory nav so I’m going to be keeping the stock deck in place (first time ever not having an aftermarket deck) and using a lc2i. For subs I’m gonna run a JL Audio w6 12ae in jl factory box ran off a Jbl 751ez amp.
I’ll eventually upgrade the speakers and run a 4 channel but I’ve always ran new wire because I’ve had older vehicles that are easy to take apart and don’t have to worry about fudging them up in the process. I’ve never used 9 wire and even though I’m not gonna be running a ton of power the highest awg I can find is 18 same as most factory speaker wire.
Thoughts?
Who else uses 9 wire?
I have a new roll of 9 wire ..stinger brand...I don’t remember if it’s 18 or 16g ..I haven’t had a chance to try it out yet ..
Prolly 18awg. I've used the stinger and audiopipe with good success.
OP you could buy the individual colors you want, twist them together and wrap them in techflex. I did that for my aux switch panel minus the techflex
I figure it’s 18g as well ..I figured I’d need it for a project eventually
This is what I ordered from Amazon. https://www.amazon.com/gp/product/B07MXMPHKS/?tag=caraudiocom-20...
325
the AVIC was a tad more complicated to wire not to mention stuffing it in a smallish stereo hole. thanks for advice.
819
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
976
It mostly comes down to weight. You can have a super lightweight cone, soft suspension and aluminum coil on a sub and you pretty much get a pro...
969
MattinMO
MattinMO
St.louis, MO
Louisiana_CRX
    Jun 3, 2024
