Best Enclosure for my X-15s
  • 6
Alejandro14
Texas
i have 2 x-15s wired at 1 ohm to a sundown 5k .. voltage steady wont drop 14.5 ...
i have a them while i was breaking them on a octo port tune to 28 on a memphis mj.2200 sounded great and played the lowws beastly
but what do you guys recommend its for a 2007 f150 crew cab
my dimensions are 33 of height ‘ 58 of length and 21 of width
i want to murder the lows be windy and be loud i atleast want to be able to play 45 hz down to 20 to shake things up and move air
subs forward port up towards the back.8.5 tuned to 32
Subwoofer forward port up or subs up port up.
Build big. Like 9cubes tuned to 30hz //content.invisioncic.com/y282845/emoticons/yumyum.gif.0556df42231b304b9c995aefd13928a8.gif
I agree, tune that suka low....29-31hz in about 9ft3 for some killer lows... port it upwards subs front and go big for sure... maybe with a big aero
I have a bit of experience getting low in a extended cab. If your trying to be loud and low subs up port up or subs up port firing to the side. I’ve had best luck with both upthough. Unless walling i would not fire subs and port forward. I’ve lost every time that way. Had my x-15s in 10.4 tuned to 28 but that was a little less power than what your running. They got low and moved some air.
On a sealed sub box if I faced the subs up, I lost quite a bit of bass. Faced them forward, they worked great. On a ported box with subs and...
592
Not good for introducing new guys to lithium Lots of burned down cars from user error because the tech is new and people are ignorant.
24
Alejandro14
Alejandro14
Texas
Lbetts818
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
