Rockford Fosgate 360.3
  • 4
My head unit is pioneer 8201 nex and I want to get the RF 360.3 sound processer but it has a front 1 and a front 2 and the head unit only has 1 front how would I use the front 2 on the processer
you dont need two front rca inputs. All you need to do is plug in front, rear, and sub rcas. Hell, you can just get by with a single RCA input into the aux connection.
You are overthinking this.
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
roger that, just got one from sonic electronix for $189. thanks for the help
18
Maybe ask RF tech support. I wasn’t able to find that either. Sonic electronics and Crutchfield just use the same description as the rf site. True...
After looking at amazon for kicker q product details, it showed rms of 1200@2ohm If you’re at 2ohm you’re not feeding it enough power. At 1ohm...
PICKELITESOUNDZ
PICKELITESOUNDZ
Chicago
BAYAREAFILMS
    May 10, 2024
3toneEYZ
    May 10, 2024
