Can I️ feed my amps with rca outs on a Bluetooth device?
  • 4
HardcoreBob
Dallas
I’m still running into all kinds of issues retaining my stock HU and while supplying my amps with preouts...
(I️ have a RF DSR1 to solve my issue, but no firmware yet for my vehicle)
My question is, can I️ get good quality sound using my tablet as a HU through Bluetooth connectivity...
The blue tooth device would have one set of RCA outs, that I️ could feed my DSR for good sound right?
Sent from my iPad using Tapatalk
It's probably going to sound better than a mess of a signal from an improperly interfaced stock system.
My only other option -at the time-is splicing RCA jacks to speaker wires pre-factory DSP...
(My two better options are the DSR/maestro combo, but they haven’t released firmaware for my vehicle yet, or a pac amp pro device that I️ can’t find the one for my vehicle in stock anywhere, both those options are plug and play...)
I️ was hoping I️ could get a good signal from the Bluetooth set up temporarily, but if it’s no better than splicing on the RCAs I️ would just use them.
232
450
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
You don't need two amps. The speakers come with crossovers to help protect the tweeters.
14
Perhaps you changed something without mentioning it here? Maybe a loose turn on line? I dunno man...but we'll take it. Hopefully it keeps working. 👍
16
HardcoreBob
HardcoreBob
Dallas
Darth_Immitis
    May 22, 2024
    May 22, 2024
