1st/2nd gen Ford Focus sedan sealing trunk
  • 1
Darth_Immitis
Anyone here have experience with this exact car sealing off the trunk completely (I put 1st/2nd gen because the interior and exterior is basically the same)? If so how many db did you gain or lose? I keep hearing its car dependent that's why I'm asking before I waste my time, thanks!
Ive seen so many amps done this way over the years. Especially ones that had the Molex plugs and a couple others
9
670
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
I honestly think that stock locations work great for 90% of the people. With today's DSPs, you can move the listening position anywhere you wish...
918
Yes Frame is best if second battery is in the rear.There are plenty of bolts and even unused holes in the Frame that can be used for an excellent...
7
Darth_Immitis
Darth_Immitis
Massachusetts
Darth_Immitis
Chris Gerrish
    Apr 25, 2024
Chris Gerrish
    Apr 25, 2024
Latest topics
