Adire Audio Brahma MKII
SoCalBean420
Cali
Item(s) for Sale: Old school xbl^2 goodness.
Item(s) Description/Condition: used, but in excellent condition. 100%
Specs:
Fs 26 Hz
Qms 5.3
Qes 0.52
Qts 0.47
Vas 99.1 liters
Znom1 1 Ohm parallel
Re2 0.65 Ohms parallel
Le3 0.9 mH parallel
BL 14.33
Sd 749 cm2
Xmax 27.32mm one way linear
Pmax4 1600W RMS, 4800W peak
SPL5 87.1 dB @ 1W, 1m
Diameter 15.5"
Cutout 14"
Depth 8.25"
Price: $375 + shipping
There was an issue with the shipping with the previous buyer. Once again it's available. $325 + actual shipping from 93306.
What kind of box does this like?
Driver does excellent in both sealed and vented enclosures. I personally had it in a 2.2^3 sealed enclosure powered by a PG Tantrum 1200.1
It was a system from 2 vehicles ago. The enclosure was rock solid. Had a P9 combo to deal with whatever equalization was going to be required.
Can't go wrong with either sub, but the Brahmas seem to have a little more "oomph" down low. Obviously both subs do fine down low, but the...
i agree i agree i will be running a pretty mild setup just 2 skar 12s at 1200w and the 4 6.5s still not sure abt fronts. i eventually wil b...
13
125
The siq amps are Sq beast as well. And much cheaper. Made by s&I in Korea iirc
171
SoCalBean420
SoCalBean420
Cali
SoCalBean420
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
