Can I connect my car subwoofer amp to a 2 channel receiver?
  • 2
Based
Louisiana
Well since I am going to start building speaker enclosures I need some place to test them. I drive a Miata so I don't have a vehicle to really put any enclosure in so I figure I will just set it up in my room.
I researched how to get power to a car audio amp in my room via a PSU but how can I connect the amp to get signal from a 2 channel receiver?
I want to have a pair of mids/highs on my desk and then a subwoofer (or 2, or 4 lol) on the floor. The mids/highs will be getting power from the 2 channel receiver and the subwoofer will be getting power from a car audio amplifier. Then the receiver connects to my PC.
Do receivers have an input for RCA connection from an amp to the receiver? I am looking at receivers and most of them have a few red/white inputs or outputs but I'm not sure if that's what those are made for.
If they are RCA outputs from the receiver/head unit, then yes. Line level outputs we used to call them, signal designed to go into a power amplifier's inputs. Or are you talking about a home stereo receiver? This is probably true regardless.
John Kuthe...
What is your budget? With being exposed to Rain.. I would recommend looking at a marine grade SAS Bazooka for the sub stage
269
the AVIC was a tad more complicated to wire not to mention stuffing it in a smallish stereo hole. thanks for advice.
8
434
I agree; it doesn't. :) See my comment above on Tuesday at 4:08 pm; in short, I'll use the auxiliary port on the FM transmitter.
5
The end result is, not the intention. I think OP got what I was saying. The Brits generally aren't as sensitive. A 500w sub amp does not...
17
3K
Based
Based
Louisiana
JohnKuthe
Doxquzme
    May 10, 2024
3toneEYZ
    May 10, 2024
