will there be an audible difference between a 2" and 3" coil ?
  • 1
GavinVoy
stupid should hurt.
looking to change things up a little bit. I have had the same setup for a few years now. Right now I have a custom SPL audio Treo ssi, coil is 3" that can take 2K, because it used to be on my MMATS D2100.1. But now it is only on 2x channels on my Sundown 125.4, getting something like 300 watts.
I was wondering, changing to a sub that had less headroom would make much of a difference. Like less mass would make it more efficient? Looking at the Dcon 15" cause its $150 right now and cause it is a 2" woofer.
According to the Taramps site, there are three variants: TARAMPS SMART3 BASS 1 CHANNEL 3000 WATTS RMS 0.5 ~ 2 OHMS CAR AUDIO AMPLIFIER. TARAMPS...
I can hear the difference. A typical component system will have a superior tweeter and crossover, although I've noticed component crossovers are...
Just thought I'd quickly update this thread as it's been a long while since I promised an update, I finally checked the AC output of the speaker...
23
6K
Lower the ohm the thicker the wire. The higher the ohm the thinner the wire but will have more windings. Lower ohm coils have a slight edge when...
GavinVoy
stupid should hurt.
GavinVoy
St. Louis, MO
GavinVoy
vlusardi
    Apr 27, 2024
winkychevelle
    Apr 27, 2024
Latest topics
