Seen this video over on Facebook.Amps don't look too bad at all.I know lots of people always looking for budget bang..
http://www.rockvilleaudio.com/RXD-M4/
What i thought too but for the price they didn't do bad on the dyno.I'm not in the market but i know LOTS like the cheaper the better approach.lolI am using a set of their 6x8 comps, on a alpine power pack amp, sounds decent for what I paid. Would I recommend them, I don't know, but at least something to look at.
not with them becaues the way they rate things are stupid my amp is rated for 2000 rms but as you can see mine does 1000 if you look at the youtube video the ces rateing for that amp was 1500 and thats what it did but on there paper work its 3000 rms but thats really just the peak rating basically there ces rating is the true rms it took me a while to figure that out why they rate it like that idkCEA-2006 ratings tests are done at 4 ohms.
I don't have an intimate understanding of CEA-2006 as it's not needed for my job, although I am certain the testing is done with 4 ohm speakers. Where is Rockville's 4 ohm test report?not with them becaues the way they rate things are stupid my amp is rated for 2000 rms but as you can see mine does 1000 if you look at the youtube video the ces rateing for that amp was 1500 and thats what it did but on there paper work its 3000 rms but thats really just the peak rating basically there ces rating is the true rms it took me a while to figure that out why they rate it like that idk
This is what I hate about car audio you're judging a product by the price obviously you never used it let's ignore the Amp dyno lets ignore everything it's cheap it's ***** I'm one of those people that's willing to try anything once and like I said for the cash is not bad at all this cheap little thousand watt amp sounds almost identical to my AQ that cost twice as muchThey are not doing a CEA rating if they are not doing it at 4ohm. Cheap brand is cheap
Nope you're absolutely right that's how the CEA rating works but these people are just backwards that's all basically - my amp is 2000 watts peak 1000 watts at 1 ohm but the way they rated is -2000 watts RMS and 1000 watts cea certified which makes absolutely no senseI don't have an intimate understanding of CEA-2006 as it's not needed for my job, although I am certain the testing is done with 4 ohm speakers. Where is Rockville's 4 ohm test report?
Let me know how they hold up bro //content.invisioncic.com/y282845/emoticons/thumbsupwink.gif.129404938effda6ad9cca39e7f4b58a3.gifThis is what I hate about car audio you're judging a product by the price obviously you never used it let's ignore the Amp dyno lets ignore everything it's cheap it's ***** I'm one of those people that's willing to try anything once and like I said for the cash is not bad at all this cheap little thousand watt amp sounds almost identical to my AQ that cost twice as much
