How to wire two dual 4 ohm subs to 2ohms?
  • 5
I guess the only way to really get a 2 ohm load from a pair of dual 4 ohms is to use 2 amps. Each one running 2 ohms. It's more complicated this way and kinda pointless if you ask me. You're better off running at 1 ohm with one amp though as it's the best bang for the buck. If your amp is not 1 ohm stable, then get one that is. Otherwise getting a lot of power at 4 ohms is expensive. Some of the old school amps you could bridge at 4 ohms though, which is just as good.
You can short one of the VC's on each sub (jumper + to - on one VC and don't connect it to anything else). Then you can wire the other VC from each sub in parallel to get a 2 ohm load.
IF you do this, then derate your power by ~75% to be safe.
I ran a JL dual 4ohm VC sub like this for years without any issues at all. The theory behind shorting the unused VC is that it increases damping so the sub & enclosure behave roughly the same way it did with 2 VCs wired.
There is a paper written about the theory on this somewhere - I will look for the link later.
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
8
760
It mostly comes down to weight. You can have a super lightweight cone, soft suspension and aluminum coil on a sub and you pretty much get a pro...
4
766
GuysIGotThis
Ottawa, ON, CA
Jepalan
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
Latest topics
