Planning to either run an SA-15 or a GCON 15" so I need an amplifier to power it. Anything will be acceptable.
I am only powering a single 15" so I could wire it to either 2 ohm or 1 ohm. What do you have?I got something in that range. You need that at 2 ohms or 1 ohm
How much? And I don't want to have to upgrade a battery or alternator so I can't put too much. What sub would you think?A vfl 80.1 Leaves room for another sub. Or a better sub to
PmedWhat kind of sub? I don't want to have to do anything more than a big3 for electrical and I have a crap alterantor so
What size sub ? I've got a 10" or a 12"How much? And I don't want to have to upgrade a battery or alternator so I can't put too much. What sub would you think?
The sa 15 can take a good amount of power if the signal is clean. After box rise and resistance. You'll prolly see closer to 1000 rmsPlanning on a 15
