Schematic for 02 Cadillac Seville
  • 2
accuab
I'm trying to add on a 4 channel amp and sub amp to the stock setup in a 02 Seville with the non-bose setup. Anyone have the color coding for the wires at the factory amp to tie in for the signal? I've checked on google and cadillac forums to no avail.
Does the factory plug that goes into the radio a 32-pin plug? If so then the attached diagram may help. You could replace the factory radio but some caddies have problems if the factory radio is removed, things like losing memory settings, factory alarm goes haywire, remote lock randomly stops working, etc... but the easy solution to that is relocating the factory headunit to the trunk, mine used to sit above the wheel well.
Resonix is supposed to be the bees knees, but it is a little $$. If I was doing the whole car, probably would shell out for the entire resonix...
25
accuab
accuab
Athens, AL
Wingman0121
    Jun 3, 2024
