Running grounds help!
  • 4
Are you asking if you should re-use the factory grounding points? If so, you'd be well served to make new ones, with the engine ground as close to the alternator case as possible or better yet, at the alternator case.
No I already upgraded big 3 with 1/0 Stinger hpm but I got wire leftover so I want to put in second run. Just wondering if I should just put second run on same grounding points I used for the first run(strut tower and tranny)?
---------- Post added at 02:44 PM ---------- Previous post was at 02:43 PM ----------
I am guessing I should also have two runs from rear strut tower to rear batt bank?
With a rear battery bank you really don't need to add any grounds to the front. You need to run at least as much or more ground wire from the last battery only in the rear bank.
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
427
Is that a car show? Wow. Too much ground loops. The magnetic field may interfere with frequencies going to the antenna. Or you just need a...
15
Thanks for the feedback. It was a long shot but there will definitely be much more powerful subs in the trunk, so clearing it out isn't an option...
ta2ed9783
ta2ed9783
enterprise, al
bbeljefe
    May 10, 2024
3toneEYZ
    May 10, 2024
