95 Range Rover stereo installation help!
  • 3
SwedishChef
Hi there, I have a 95 Range Rover 'Classic' with the factory Harmon/Kardon upgrade. The system has 6 speakers plus a factory amp, subwoofer and external CD changer.
I replaced the factory AM/FM/tape head unit with a Parrott RKi8400. I had to splice the wiring because I couldn't find a harness adapter. I did this very carefully since I know it's a bad idea. After I did that, NO sound whatsoever came out of the speakers.
I then took it to my local Al & Eds shop and he gave me a R+L (what looks like) RCA cable to plug into the (yet unused) RCA R+L jacks on the back of the head unit. Now I get sound but it won't fade front to back, and there is a lot of ground/RPM feedback, and a loud pop when the stereo starts up and shuts down.
Any help on how to remedy this would be very much appreciated!
you are feeding the factory amp from the aftermarket head unit. the factory amp should turn on/off with the head unit - that means using the head unit's remote turn-on wire to feed the factory amp turn-on (making sure it's not the power source for the factory amp which would require a relay).
for signal, if the factory amp can use the speaker outputs from the new deck as the input, that may be a better choice than unbalanced RCA. using RCA, you need to make sure the shields (signal ground) are properly handled in the factory amp.
Another issue I forgot to mention is that the volume knob on my new HU is incredibly sensitive. I have to stay within the 1-4 range of a 30-degree volume knob or else it just blasts like crazy. AL & Ed's guy said this was because it's using the RCA instead of the standard speaker wiring or something.
I don't know if it's the power source for the amp or not. How would I test that?
This is how I had it wired initially - without using the RCA cables, and I got no sound at all with this setup.
depends on how the speaker wires are connected. if you wired the speaker wires into the same wires you connected the RCA's into - it would work. but you may still run into volume issues (though noise would go away).
massive volume changes means the signal is too strong. you may be could use a ground loop isolator and an attenuator on the head unit RCA outputs to resolve both issues.
i think you need to get some schematics of the factory amplifier and factory radio and start over.
Thanks. I know this has been done before on my car, it's just complicated. I remember that with the factory setup, the HU is not powered, the amp is powered. I suspect as you say the problem is that the HU is kicking out too much power and the amp is not expecting it. Would an attenuator and ground loop isolator solve this? If so, do you have any product recommendations?
post some pics of the harness that was plugged into the factory deck. Or did it look like thishttp://www.crutchfield.com/p_120701784/Metra-70-1784-Receiver-Wire-Harness.html?tp=2977. how many plugs were there? If you have the factory amp wired to the rca's then changing to the speaker outputs will only put more power to the amp and increase the actual volume. you may have to use something like this to get proper volume levels.Pac-Audio.com Product Details | iPod Integration for your car and More by Pac-Audio - Connecting you to the future This may also take care of your popping issue.
correct, that is what i meant by an attenuator (also called a LOC) if you use speaker wire outputs.
if you use RCA outputs then you can get RCA attenuators that go in-line, one per RCA.
I'd rather use the speaker wires than the RCA because then I get my fade control back. Yes- all the right & left speaker wires are currently going into a single right and a single left RCA. I will try to get some docs & schematics to reference. Worth noting that right now it is using the RCAs and there is still a LOT of whine with RPMs
Here's the back schematic of my new head unit, the Parrott RKi8400, And here's the link to the full Parrott RKi8400 PDF
It looks like the problem might be that the stereo doesn't have "pre-amp" inputs?
Here are some pics I found of the same factory stereo I had in.
And here are the schematics for the factory radio wiring:
As I understand it, I need to use the speaker wiring as opposed to the RCA's in order to keep my front/rear fade control. I found 4 products that seem to fit, the first one has a 12v AMP trigger, which sounds like something I may need?
1) PAC SOEM-T 2-Channel Premium Line-Out Converter with Remote Turn-On Trigger
2) Scosche Loc80 2-Channel Adjustable Lineout Converter
3) PAC SNI35 Adjustable 2-Channel Line Out Converter
4) Boss Audio Systems Car High Level to Low Level Converter (B65N)
Will any of these work or do I need to get the first one with the 'remote turn-on trigger'?
Just pulled out my Parrott rki8400 head unit and compared what's going on to the Navone product (above) I purchased. One thing I am initially concerned about is the product description from the website:
"will perfectly interface to any OEM automotive system to an aftermarket power amplifier, equalizer, electronic crossover, etc."
This is exactly the opposite of my issue - I have an aftermarket HEAD UNIT which I'm using with a FACTORY amplifier. Not sure if this matters, any input would be appreciated.
The Navone product has 4 RCAs on the AMP end, and 8 speaker wires to the head unit end. The wires going to my AMP do NOT have RCAs, but are split into 8 positive & negative speaker wires. I'm assuming it's fine for me to strip the RCAs from the Navone unit to split out the +/- wires from each RCA to connect to the 8 +/- wires going into my HU?
Thanks again guys for all your help. Can't wait to get this thing up and running !
Just spoke with David Navone. What a hoot! He's great. He also happened to know my 95 Range Rover Classic very well. He assured me it was the right product and that splicing out the RCAs would be fine. Looking forward to getting the unit in tonight!
Hmm. Okay do I installed the Navone. Not great. It basically made the volume even MORE sensitive and the speaker POP is still there on startup & shutdown, and now I have a louder, more constant hum. I spliced it into the head unit speaker wires, not the RCAs like I was using before.
One thing I noticed is the factory labeling on the wires out of the head unit show PINK = ACC + and YELLOW = Line Mute. These are opposite from the coloring of the stock wiring harness. I will try swapping them tonight and see if there's any difference.
Other than that, any ideas? Hope I can get this sorted. Just spent $40 and two weeks on getting nowhere.
The difference in 96 to 98 db is going to net you about an 22% difference in output, all things considered equal. When it comes to 325 per channel...
8
514
Yeah but accubass only restores the bass roll off. It doesn't take an incomplete signal range and make it a full range signal.
13
Okay, couple of suggestions With this being a sealed enclosure. Play with the position of the enclosure. Sub firing back, sub firing forward, and...
8
Hpf set to 80hz door speakers really shouldn't play lower than that without specific design inputs ie: sealed doors, fully deadened doors, mounted...
SwedishChef
SwedishChef
Ft Collins, CO
SwedishChef
SlugButter
    May 4, 2024
slater
    May 2, 2024
Latest topics
