Design Questions for 10" JL Audio 10 10W0v3 in 0.65 Cubic Ft Enclosure
  • 2
Turpy
Vehicle : 2008 Ford F-350 Lariat 4x4 Crew Cab
Location in the vehicle: 1st choice is behind the rear 60/40 bench seat or 2nd choice is a console box in the middle on the back seat floor.
Space available (Length x Width x Height): Depends on location
Subwoofer make and model: JL Audio 10W0v3
Subwoofer Size: 10" (4.9" mounting depth)
Number of Subwoofers: 1
Type of Port (Kerfed, Slot, Aero, etc.): None
What type of music do you like?: Country & Rock
Is your goal SPL or Everyday Music?: Everyday (Thump)
Tuning Freq (Hz): See Below
Volume : 0.65
Questions: I want to build the cheapest enclosure rather than buying one for more than 3x the price!
Here is the recommended box specs from JL Audio:
Wall Thickness: 0.75 in / 19 mm
Front Baffle Thickness: 0.75 in / 19 mm
Volume (net int.): 0.65 cu ft / 18.41 L
External Width (W): 18 in / 457 mm
External Height (H): 11 in / 279 mm
External Depth (D): 9 in / 229 mm
F3: 42.4 Hz
Fc: 53.23 Hz
Qtc: 1.002
Well, ya see that's just the thing. The dimensions are so complicated that I'm simply hoping that someone already has plans for my truck. I know how to calculate air space and build a box, I just need help deciding where and details. I have found a box online, but they obviously don't give away their dimensiona. Maybe I'm asking the wrong people.
If you're serious about an 18 in the trunk front firing/trunkwalled go ahead. At least you got electrical covered /w/ a 600rms sub I'd wager. If...
16
3K
Not sure if this is reliable but trying to figure it all out on my own at this point. Does this look good?
737
So I was wondering what would yall use to design your box. I just don't wanna do black carpet or black bedliner paint bc to me I want something...
Thanks man! Quitting drinking and battling DRESS syndrome has given me a new outlook on life.
8
402
Turpy
Turpy
Elwood, IN
Turpy
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
Latest topics
