eldefontes 10+ year member
Item(s) for Sale:JBL MS8 Processing Unit
THIS IS A BRAND NEW REFURBISHED UNIT. Just got this item from Harman as a replacement from the one that had broke. The display insert port on the MS8 broke when trying to insert the displays cord. They told me that they considered that physical damage but under a 1 time courtesy they would replace the entire unit. Item will come exactly in same box as I received it from with the same plastic and foam you see in pictures. Reason for selling - bought mosconi 6to8
General Specifications
Type System Integration Digital Processor
Power Output 20W x 8 channels @ 4 ohms, 30W x 8 channels @ 2 ohms
Series MS Series
Audio Specifications
Number of Output Channels Up to 8
Maximum Input Voltage (Speaker-Level Input) 15V
DSP Time Correction Yes
Output Connections 8 x line-level; 8 x speaker-level
Signal-to-Noise Ratio (Line-in>Line-out) 90 (Line-in>Speaker-out) 85
Number of Input Channels Up to 8
Built-In Amplification Yes
Electronic Crossover Functions DSP, up to 8 outputs, 6dB/12dB/18dB/24dB/octave
Seating Position Optimization Driver, front passenger, front area, rear area
31-Band Graphic Equalizer Yes
Tone Controls Bass, Mid, Treble
DSP Equalization Yes
Maximum Output Voltage (Line Output) 2.8V
Frequency Response 20Hz–20kHz
Input Signal Conditioning Yes
Maximum Input Voltage (Line Input) 2.8V
Audio Connectivity
Input Connections 8 x line-level; 8 x speaker-level
Aux Input Yes
Other Features
Favorites Settings Up to 5
Remote Control
Remote Control RF
Surround Processing
Logic 7® Surround Processing Yes
Video Specifications
Display 128 x 64 pixel LCD
Dimensions
Display Depth (in) 2-7/16
Display Depth (mm) 62
Display Height (in) 3-1/8
Display Height (mm) 79
Display Width (in) 3-3/8
Display Width (mm) 86
Main Depth (in) 11-1/2
Main Depth (mm) 293
Main Height ( in) 2-1/8
Main Height (mm) 55
Main Width (mm) 187
Weight Display Unit (g) 80
Weight Display Unit (oz) 2.8
Weight Main Unit (kg) 2.9
Weight Main Unit (lb) 6.4
Weight Remote Control (g) 40
Weight Remote Control (oz) 1.4
Price:$300 (not including shipping)
Shipping and Miscellaneous Item Information:Item is shipped from Columbia, MD by UPS Ground. Can arrange pick up if local.
Also selling the Arc Audio SE 2075 2 Channel, if you want both will do 500 for both not including shipping
Series MS Series
Audio Connectivity
Aux Input Yes
Other Features
Remote Control
Remote Control RF
Surround Processing
Dimensions
Main Depth (mm) 293
Main Height (mm) 55
Main Width (mm) 187
