FS : (2) Sundown SAZ-1500.1Dv2 Amplifiers - $315 EA Shipped
  • 5
SkarAudio
Florida
1. Product:
(2) Used Sundown Audio SAZ-1500.1Dv2 Amplifiers
2. Specs:
Double Sided Through Hole Epoxy PCB
Efficiency : 86% @ 4 ohm, at 100Hz
24dB/Oct Variable Crossover
Multi-Way Protection Circuitry
(Thermal/Over Current/Speaker Short/Speaker DC Protection)
Variable Subsonic Filter
Variable Bass Boost
Variable Low Pass Filter
Variable Phase Shift
Zero(0) Gauge Power Supply Connectors
Tested Voltage & THD : 14.4V & Less than 1% THD
Operating Voltage : DC 10V~18V
Digital Class-D Linkable Mono Block Amplifier
1 Ohm Stability
RCA Line Input and Master Output
24dB Octave Crossover Slope
Wired Remote Controller
MSRP $799 USD
Rated power output
----RMS power, 2 ohm linkable/dual mono
3000W x 1CH
----RMS power, 1 ohm mono
1500W x 1CH
----RMS power, 2 ohm mono 800W x 1CH
----RMS power, 4 ohm mono
400W x 1CH
Signal to Noise Ratio >90dB
Low pass frequency crossover 35Hz~300Hz
Subsonic filter 10Hz~60Hz
Bass boost @ 45Hz 0~18dB
Phase shift control 0~180 degree
Frequency response 10Hz~350Hz (+/- 1dB)
T.H.D @ 4 ohm
Efficiency @ 4 ohm 86%
Fuse rating 40A x 4
Input Sensitivity 200mV to 6V (+/- 5%)
Dimensions 252(W) x 58(H) x 434(L)mm
3. Description/Condition:
Both are used but in good condition and work perfectly. The only thing worth nothing is that one of the 2 amps has a missing set screw, but that is all! Great deal on 2 amps here. Same price shipped for each.
We got these in on trade for some Skar Amplifiers which is why they are for sale - we tested them in house and they work perfectly!
4. Price: :
$315 Shipped Per Amplifier via UPS Ground. First come first serve. PayPal sales@skaraudio.com and we will ship it same day UPS Ground and send tracking.
5. Pictures:
259
10
My wife is gonna sh!t bricks when my subs get here. She doesn't know yet
19
SkarAudio
SkarAudio
Florida
fatboytyler
chipss36
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
