FS: Precision Power Ax400 (art series)
  • 5
J31Rob
CarTune Netwerk
11,827
Indiana
Precision Power Ax400 Art Series
7/10 cosmetic
5/10 mechanical
Not sure exactly what the issue is.. but the rear channels are fuzzy. It's an old amp, could be something partially blown or just a cold solder issue. Cheap fix either way. The rear channels DO work, just not 100%.
I DO have the plugs, they're just not connected in the pictures.
$100 shipped.
UPS / USPS, your call.
one of my all time favorite amps. for the money you wont find a better amp to make your mids and highs sing flawlessly.
bump for you Jrob
bump for you Jrob
I was upset when it ended up having noise. //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Just to be clear about the issue w/the amp.. front channel works flawlessly, rear channel is scratchy. Bump TTT.
$60 shipped. Let's get this thing gone. It literally half way works.. I'm giving this away I just don't give a shit about it, it serves no purpose here and I want it gone.
Guess I'll bump this back up too. Everyone forget how nice these are? Keep in mind.. the FRONT CHANNELS WORK, the rear channels do as well but just have a crackle. Could be a SIMPLE fix. Your gain, my loss.
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
437
What amplifier(s) are you using? What speakers? Is this your main battery or is it a 2nd battery? If it is a 2nd, how are you wired up? What if...
343
J31Rob
CarTune Netwerk
J31Rob
Indiana
J31Rob
SlugButter
    May 4, 2024
slater
    May 2, 2024
