4th order 2 SA8V2's in a ported through the rear deck
sbarber82
Building this for my buddy for two SA8V2 subs. It is .2 sealed each and 1.1 ported shared. Tuned to 50hz. Powered by a Hifonics BRX2400D wired 2 ohms (1600 watts).
Porting it through the rear deck in his cadillac deville with a aero port. Got the cuft measurements from T-fade. This little beast should be pretty loud!
interesting setup there, I'd also love to hear what this sounds like //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
Good design, but I would be real worried about the sealed section being that small. Not saying it wont work or sound good, just never seen any Sundown design run in a sealed that small. Ive got a 4th order design for an sa8 and mine is about .50 with the sub inverted @ 50 hz and it was done that small for space requirement.
you may like them facing forward rather than Rear faced. Its all about how you like and enjoy by your ear/listening not others. try Both...
845
is this a ported enclosure or a 4th order? If 4th and tuned to 33hz, unless specifically designed to do that, it wont have any bandwidth. It might...
I’m going to stick with the 4th order bandpass for now and see if it can improve it. The bandpass actually plays 100 rebased songs good.
I'd try rear facing. Have you tried opening the trunk to see if that restores your bass?
Any direction you orient a sub can affect it's output, this true even more so in a car. Nevertheless it doesn't add an order and generally...
sbarber82
sbarber82
Vegas baby
drummer4261900
audiobaun
    Apr 27, 2024
audiobaun
    Apr 27, 2024
