Head unit power cycles when turning headlights off/on...
geowick07
Hi all! Been a while since I've been the forum. But I have a problem I need to fix as quick as possible!
I installed a head unit in a friend's 2000 Jeep Cherokee Sport, (Sony XPlod...not sure on model # ATM, but I can find it if necessary). All seemed well, until later on in the evening he turned his headlights on, and the head unit basically power-cycled, i.e. turned off, then right back on. It does the same thing when turning the headlights off...power cycles off then back on.
Is there something I could have wired wrong? I wired the harness the same as I have any other time, and I have never encountered this issue. Bad ground, maybe? I didn't use the illumination wire (can't remember why right now, but I know I did it deliberately.)
Any help is greatly appreciated! I hope to be able to remedy this ASAP, since it isn't my vehicle. Thanks in advance!
geo
Bummer. I suspect the power wire you picked has something to do with night/day functions in the Jeep. You should be able to verify that by reading it with a DMM while playing with headlights. Find a different power wire.
I actually fixed this Saturday, but am just now able to update. I had a family medical issue to attend to.
Turned out to be a bad ground. I did some reading elsewhere, and found many instances of people having bad grounds in Jeep factory wiring. I ran a new ground from the HU to the body, and no longer have the power loss issue.
Thanks for the suggestions!
geo
***Moderators, please feel free to delete this thread, if deemed unhelpful. Thank you!***
Tháo dỡ, bảo dưỡng, lắp đặt điều hòa giá rẻ nhất Hà Nội.
Liên hê để được báo giá tốt nhất. (không rẻ không lấy tiền)
Hotline: Mr Phương: 0904785139
I have read about this, and honestly the installer did nothing wrong. It's the newer vehicles that have the automatic engine stop/start (instead...
949
https://www.taramps.com.br/en/produto/amplayer-400/
5
There are a couple of options. You can use a marine bt unit. They come in the size of a hockey puck and can mount anywhere. This is the marine unit.
438
There are bluetooth amplifiers. You can just use your phone or an I Pod as the music source and not touch the radio.
Avoid jvc 480bhs hard to see the display in the daytime even with the brightness all the way up also not as easy getting to the audio menu like...
5
591
geowick07
geowick07
Warren, Michigan, United States
robert420
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
Latest topics
