Advice on HU power 6x9
If he ever plans on amping them Neo then I'd suggest some of which you posted. But he's using a h/u that puts out
Ehh fair enough and apparently I skimmed right over the factory radio part.
OP, you'd probably see more gains just from amplifying your speakers rather than replacing them. Try that first, then revisit replacing your 6x9s
I think he should go with the Lanzar off of the HU power, and get funds up to do a very nice install for amped speakers,and a single sub set up,and not waste money on good expensive quality speakers that will more than likely get clipped to death from distortion.Keep it simple I say, till you get the funds for a entry level set up.I think you will be surprised what the Lanzars can produce for you for your money.Just my 2cents
Signal flow should be HU to DSP to amps. You would lose the ability to EQ and time align the sub with the DSP unit if you bypassed the DSP.
The HU us likley 12-15 x 4 at best so yes, using an amp will be hugely beneficial, night and day. The HU us not going to drive a sub to any...
170
388
I always leave approx 6" or so for that very reason, in case I decide to swapp an amp if needed,or wanting too.RCAs ect. I deff do the extra 6-8"...
473
Honestly, beyond what you need. It will do the trick for sure, but it is excessive. Not a bad thing, just more than you will ever need. No need...
duckfart
duckfart
Long Beach, CA
Sleeklsc
Chris Gerrish
    Apr 25, 2024
Chris Gerrish
    Apr 25, 2024
