New kicker bass knob zx models brand new
  • 2
I have a Stelvio in which I plan to replace the factory 8” sub for a CDT QES820. I already have an LC2i and NVX BDA7051 amp. So it will be a good...
No reason you can't get the sound you want with ported or passive radiator but if you have no ability to tune the mass of the passives you will...
7
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
502
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
995
DrBass12345
DrBass12345
Ky.
lysfys
Brendon Jenness
    May 8, 2024
Doxquzme
    May 8, 2024
