Making a custom 6.5" bracket in my '04 GP
  • 2
blabo219
Well i've never done a custom MDF bracket for door speakers so heres how I plan on going about it but please let me know if there's a better way.
Cutting a 3/4" MDF ring to sit the woofer in just as wide as where the screws go in, so 1/2".
Now I was going to try to make a square with four supports going to the sheet metal and fasten those in, with whatever is suggested, maybe some T-nuts.
Then I was wondering, since the supports are in a square should I make a box around the four sides, just leaving the speaker hole to the door open? not sure if it would improve mid bass seeing as how I already have damplifier pro on my doors.
Suggestions please!
Self taps 1", 1 1/8" and I wounding bother with a pod unless your gonna get technically and figure out what size the pod needs to be to work right. Other than that I would just suggest cutting the first plate a little bigger than nessecary and trim it down to what is needed cause you can cut wood down to fit but u can waste a piece if it is too small. And make sure the driver and passenger will be the same I've had a few cars where they have to be made a lil dif side to side
Well it was hard to get any useful info out of there with your proper grammar..
Does it matter the size/shape of the "pod" i figured its not really a box so it can't be causing any harmful effects on the sound.. other than maybe the fact that it might perform better free air?
Whoa, that will be one skinny port. The width of the back wall ports will be 1.08" wide (27.5mm), but the front port will be shared by 2 subs so...
5
754
I had this same issue with my Sony. When I first got it I had speakers hooked up to the head unit without amplifiers and it worked fine. Once I...
Looks like half a dozen other makes/models on the market, rebranded . The shallow mounts look like they’re made by Pioneer but what the hay, one...
8
I think it worked .just odd bc it's brand new but I appreciate it man. haven't had any problems yet
4
Is that speaker in the existing rear deck? Are you running a sub in the trunk?Do you have that speaker on an amplifier?Are you using a stock HU...
5
blabo219
blabo219
Battle Creek, Michigan
blabo219
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
Latest topics
