low battery
whojohnjones
my battery voltage wont go past 12.4 vlts with amp power line connected (even with amp off) and after a while my car battery will be low enough so it wont crank everything else will work but wont crank but if i disconnect the line from inline fuse the volts will go up...is my battery too small or what
memphis mcd-1000 amp running at two ohms
Check all of your wiring. I'm running a 760 watt to my subs and an 800 to my doors and it does fine. It sounds like you're losing voltage somewhere so that would be the first thing i checked. After that, it could be your alternator.
250
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
458
Just for examples sake regarding electrical, I have 1400 watts total between both my amps and my system has no trouble running everything max...
27
Some manufactures actually cut out some of the low end to prevent speaker damage to the factory speakers. I would consider trying one of these for...
whojohnjones
whojohnjones
mississippi
whojohnjones
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
