1/0 screw terminals?
  • 4
Price is a con, but if you feel better using the screw type than crimp then they're obviously fine. They're also bulkier in size, depending on where the terminals have to fit, they sometimes won't fit where a crimp type would. What comes to mind is the fuse holders that just have the two posts and you use a ring terminal to connect each side to the holder. Most of those have warnings that tell you up front that screw type terminals won't fit. Overall performance though, I don't see either really "outshining" the other.
hmm might be an option then.
I do not have a crimp tool or vise, and my soldering skills are lacking.
Just looking for an alternative.
They really are. Fit to perfection! Sounds Good Stereo are the best.
Yea. That's what I did. I mixed the glue with the dust from sanding and fill in the bigger holes. Then filled the rest with wood filler..works awesome
True but at those prices, nickel plated copper or brass would be a much better option for speakers, no point in using stainless steel at all...
24
356
I like the way these look. But whatever I do it has to be top post. My battery is on the driver side and right beside the air filter housing. So...
658
azphat12
azphat12
Tulsa, OK
rangerboy101
    Apr 26, 2024
    Apr 26, 2024
