1/0 screw terminals?
  • 4
Price is a con, but if you feel better using the screw type than crimp then they're obviously fine. They're also bulkier in size, depending on where the terminals have to fit, they sometimes won't fit where a crimp type would. What comes to mind is the fuse holders that just have the two posts and you use a ring terminal to connect each side to the holder. Most of those have warnings that tell you up front that screw type terminals won't fit. Overall performance though, I don't see either really "outshining" the other.
hmm might be an option then.
I do not have a crimp tool or vise, and my soldering skills are lacking.
Just looking for an alternative.
They really are. Fit to perfection! Sounds Good Stereo are the best.
Yea. That's what I did. I mixed the glue with the dust from sanding and fill in the bigger holes. Then filled the rest with wood filler..works awesome
Nobody is bashing anything. Just because I can use stainless, doesn't I should. The bananas I use are 4mm BFA style gold plated copper, pretty...
32
750
I like the way these look. But whatever I do it has to be top post. My battery is on the driver side and right beside the air filter housing. So...
666
azphat12
azphat12
Tulsa, OK
rangerboy101
slater
    May 2, 2024
slater
    May 2, 2024
