Lets talk ports?
EarDrummin.
Is this my Brahma?
3,542
Wanaque, NJ
K.. I'm having a lot of trouble designing a ported box. Everytime I think I've got it, I'm wrong. Is there a simple equation that determines frequency? Such as.. Volume of box / volume of port?
I've seen those little web page calculators that determine round port volume, but I **** at math. I can't figure out the same-volume demensions of a slot port. There an equation for this as well?
volume of a cylinder is lengh x area
V= L x A
Volume of a box is the Height x width x depth
V= H x L x W
Find the volume of your round port and then use the size slot port you want to make and that will tell you your lengh.
The late 80's early 90's car's OEM speakers were of the same quality as today's offerings. The main difference was the rear speakers were enclosed...
10
You're not trying to figure out the mass of air in your 3" port or whatever, you're trying to figure out the mass of air that you would need in an...
Are you going to do actual aeroports with flares on both ends? I’m running a single 4 inch aeroport on my little 750 watt 12. It has flares on...
The black rca out is your mono sub output. That is the one you would use for signal to your sub amp.
EarDrummin.
Is this my Brahma?
EarDrummin.
Wanaque, NJ
Trixter
    Jun 3, 2024
