JBL 5 1/4" comps
  • 4
I think you'll see a definite improvement, from the kicker 6X8s, but I would suggest getting some scosche adapter plates and running some 6" PG RSDs that you can get for $70 shipped.
I'm currently running the 6.5in versions of those. (I found them 60$ a set on closeout at a local shop around here.)
The only complaint I have is the tweeters are a little too bright for my tastes. But the woofer is pretty beefy, and it can produce nice low end if you have a well dampened door.
I'm running 2 sets off of an Alpine 100x4. I have the filter set at 60hz, and they will go painfully loud.
I didn't see where there was a difference (didn't see a "light" or "lite" version). That said, if you can fit it, then the JBL BassPro SL 2 would...
WANTED JBL 800GTI
Slava Ukraini, Brother! Don't have that amp but good luck and welcome!
I don't think this is ideal, but let's assume you can easily mount all the tweeters. That installing them is going to be really simple, and...
13
847
Working with undersized material, adjusting on the fly, testing before setting; you sound like and old pro. You are as meticulous as alot of the...
76
5K
Kool
Kool
Michigan, U.S.A.
Ninteens
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
