Alpine HU turning off
  • 4
acarlton
VA
Hey, new guy here. I am traveling for work and 2.5 hours into a 4 hour drive my HU stopped working. It turns itself off and then tries to turn back on, but then immediately turns off. If I take the faceplate off for a while and then put it back on, the HU will work for a few minutes and then go into the same problem. Is this a common occurrence?
The HU is a lower end Alpine the is probably 6 years old and it is installed in a '99 Acura 2.3 CL. I have factory speakers in the front, and aftermarket in the back. I also have 1 12" in the trunk. I also have an Aux in for my ipod
I'm driving home today and will prob just listen to my ipod through headphones. I can get a new HU this weekend and install it if i need to, but I'd rather not if I don't have to.
Thanks a lot and sorry if this has been talked about before, I just didn't know what to search for.
make sure the wire harness is clipped in solid on back of hu.could be a loose power or ground wire as well.if thats all good, try resetting the deck.if all that dont work,maybe time for upgrade
as got bass said check the plug in the back and make sure it's firmly in place. either that or make sure that all the connections are done properly and not coming undone. could be possible of a loose connection.
though, the overheating theory does sound plausable.
when you say the unit turns off does it reset itself? as in does the time and any adjusments reset itself to the stock settings?
I don't think it is resetting, b/c I think it still has my radio presets. It has always been hot, but one argument against the overheating is the problem happened last night, after about 10 minutes and the car has been in the cold all week, and the HU didn't feel hot. I may disassemble the dash before my drive home to see if there is an issue with the plug.
The Type R subs are a really great sub. Deff ask about a DMM reading or take a DMM and check them. Dust Caps can be replaced as stated and...
110
This weekend I will be taking actual pictures for other sites. So grab it before its gone
533
FOR SALE Alpine PDX-V9
As the title states, I'm selling my Alpine PDX-V9. This is a 5-channel amp, with 500 watts being delivered to the sub channel (2-4 ohms) and 100...
Any indication that a loose wire may be the issue? I'd start by checking all the +/- connections to see if one has come lose or is starting to...
Umm the sub outputs. It's brand spanking new with an install booklet etc.
555
acarlton
acarlton
VA
acarlton
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
