Any sort of Pass-Key or similar theft deterrent come stock on that? If not, it's not too much of a problem. (Speaking from experience on installing a unit on my '88 Brougham, but that's before all this fancy computer ish)Anybody done one...how much of a PITA and what product do you recommend?
would this apply to a 99 tahoe?easy easy easy only issue i have seen is if the factory security kicks in it wont let the truck start at all and u have to wait 10 min for it to reset to start the truck. generally a bad bypass causes that. get a gmbp or GMBPDL works or a 1700g for everything
So on my 03 sierra I need to buy that 1700g on top of the remote starter?1700 g doesn't work for everything until 2003. It will do the passlock integration. Yes it's the same for 1999.
Yeah, have had the same problem before, just tap into fctory arm and disarm. Problm solvedeasy easy easy only issue i have seen is if the factory security kicks in it wont let the truck start at all and u have to wait 10 min for it to reset to start the truck. generally a bad bypass causes that. get a gmbp or GMBPDL works or a 1700g for everything
