Remote start install on 2000 GMC Sierra
Anybody done one...how much of a PITA and what product do you recommend?
Any sort of Pass-Key or similar theft deterrent come stock on that? If not, it's not too much of a problem. (Speaking from experience on installing a unit on my '88 Brougham, but that's before all this fancy computer ish)
easy easy easy only issue i have seen is if the factory security kicks in it wont let the truck start at all and u have to wait 10 min for it to reset to start the truck. generally a bad bypass causes that. get a gmbp or GMBPDL works or a 1700g for everything
would this apply to a 99 tahoe?
Yeah, have had the same problem before, just tap into fctory arm and disarm. Problm solved
Those look like decent cheaper options for sure and probably fine for some systems, but I agree, Audiocontrol has been making high quality stuff...
207
Is there an external fuse mounted near that amp going to it? If so, make sure it is not grounding out some how. Frayed wire touching ground or...
981
Usually when you shop for a replacement harness for your model, you will find the pictures may show you in what pins your wires go to.
Actually, I think I had the adjustment knob turned down while I was setting gain! Rookie mistake
31
4K
  • Locked
I dont see a Username and date on any of these pics that the FOR SALE Rules Should Apply. Are these pics off Ebay?? Place those with the pics so...
duece212
Buddy Christ!
duece212
Colorado
THUNDERBIRD
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
