How many of YOUS have alarms?
Ali1
e6300 FTW
3,643
U.S.
like the title says, how many of you guys have an alarm on your car, and which alarm are you using?
I have the python 700 w/ keyless entry, shock sensor, enhanced window breakage, and the additional proximity sensor.
2wayFM LCD- RemoteStart, Keyless, Alarm, adding(on rebuild): fuel pump shutoff, extra siren, backup battery.
nG
How haed is it to add a siren? I have an extra one sitting around that I thought would be nice to put in there as well.
Wire it in parallel.
//content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
nG
all you do is connect it to your siren power wire and ground the other..I think the siren output wire will support up to 3 sirens..
i have a compustar 2 way fm lcd pager alarm/remote starter with a back up battery and a piezo siren inside,starter kill,shock sensor,keyless entry
Alright sorry this took so long. Here's the update. I tried out all the sets of speakers, the black diamonds did not fit front or back. I think if...
23
5 ch amps can get expensive and most of the sub stage lacks power for a decent mid-sized sub. And end up running hot. Some times its best to look...
This is a little more money but well worth it from looking at the reviews. And it's Korean.
13
I wouldnt waste the time or money on OEM speakers to be placed back into any vehicle unless you plan to sale the vehicle and remove the after...
With half inch MDF, it's like 4.27cu/ft internally not including sub and port displacement. That's like 3.5 to 3.8cu/ft after displacement. You...
Ali1
e6300 FTW
Ali1
U.S.
pickup1
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
