Yet another speaker compare thread (coaxial)
  • 4
DaveDSMer
Ok so with the new amp for the hi's I need to make a new choice about speakers. Amp is rated at 50 x 4 rms (CEA compliant). From looking around this is what I have come up with. 4" in front 5x7" in rear is my size (ford ranger supercab).
Cheap - MA Audio - Cost = 80.00
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=15809
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=15812
Middle Ground - Polk db - Cost = 140.00
http://www.crutchfield.com/S-geV9C1SJPVr/cgi-bin/ProdView.asp?g=51200&I=107DB400
http://www.crutchfield.com/S-OehcR7CO9DU/cgi-bin/ProdView.asp?g=51900&I=107DB570
Higher End - JBL Power - Cost = 280.00
http://www.crutchfield.com/S-geV9C1SJPVr/cgi-bin/ProdView.asp?g=51200&I=109P452
http://www.crutchfield.com/S-OehcR7CO9DU/cgi-bin/ProdView.asp?g=51900&I=109P8652
Basically, I can see good and bad points about each speaker set. MA Audio has very high sensitivity, good size tweeters, good power handling, and very low cost but I am wondering if quality might be questionable at that price. Polks seem pretty solid with a pretty good price but I am worried about the 4" speakers power handling as its rated at 35rms. The JBL powers look great and I know they can take the power but they cost a good penny.
My main concern is being able to be strong enough to not be drowned out by my Infinity 12 which is going to be right behind the seat without sounding like crap.
If you're willing to spend in excess of $250 why don't you consider component sets instead?
Also, are you sure those speaker sizes are right? Something sounds off. I've never heard of Ford using speakers smaller than 5.25.
its an 88 ranger
Out of the sets mentioned the jbls sound the best imo, but the jbl gto coaxes sound better than teh power series you posted. If it were me, I would get some decent 6.5 comps, and make do some minor modding to make them fit.
They managed to turn Covid into a wedge issue.
Pioneer lists the wattage different than sonic. Pioneer says That amp listed will do great with these speakers. You can play em at 125w no...
4
I think you will be just fine to be honest. Id run it and check it after hammering on it quite a bit and check the temp on the wire by hand to see...
DaveDSMer
DaveDSMer
Augusta, Georgia
Towncar
Doxquzme
    May 10, 2024
3toneEYZ
    May 10, 2024
