ZX750.1 kicker
alotofbang
Im looking to but a ZX kicker 750.1 to push my two 15"4 ohm kicker comps will have them hooked up parallel for a 2 ohm load is this a good amp for them. I am also thinking about upgrading to 3 12" cvr's will this amp be able to push these with good excursion. Also if there is another amp that is better and around the same price let me know
If i missed anything ask?
7501. will be ok for the comps. if you run 3 12 cvrs you will need atleast a 1500.1 zx to get the full power they need. a 750.1 on 3 12'' cvr's will be extremely underpowered
This is a test my teamate did with a ZX750.1:
Tested on 3 Kicker CVR 12's Dual 4's, all paralled to .667ohms.
Nominal Impedence: 0.667ohms
Reactive Impedence: 1.64 ohms
Output Voltage from Amp: 41AC volts
Output Current from Amp: 25AC amps
Power Output(P=VI): 1025 watts
Current Draw: 84DCA
Voltage on burp: 12.0VDC
Not too bad for an amp rated to be a two ohm amp and playing below its rated impedence. 1000+ out of a 750 watt amp is pretty nice. This amp is 375@4ohm 750@2ohm.
alotofbang
alotofbang
denton, texas
Kenneth10483
