ZX650.4 powering 2comps & 2 coax
rmdl51
White_Shadow
Ok Thanks a lot! I have another question about this amp, it has two 4-pin connectors (+)(-)(-)(+) that say High level inputs, what are this for? the manual doesn't say anything except that if I use the HLI I should use the RCA dummy plugs in order for the fader to work properly. I don't even understand which fader means.
Maybe I shouldn't worry about that and just use the RCA's but I was just interested on learning what are those Inputs for. I will appreciate if someone can give me some info about it, Thanks again.
That's for hooking up to headunits that don't have RCA outputs, i.e. factory systems. You hook into the speaker output from the headunit instead, and feed it into the high level input on the amp.
That's good info thanks. So is the "sound card" included in the Audiofrog kit simply a 3.5mm to USB converter and not an actual sound card?
199
My experience says that for most people, usually, overpowering subs doesn't really gain much, especially for daily or music. Actual power levels...
653
The 750 will give you better control at higher volumes as you won't be reaching clipping as soon..
When you say power on for a limited time, do you mean power after the vehicle has been shut off or just turning on the radio and it plays for a...
Yes, the power wires' colors don't match from the dash to the new harness. However, I tested them and the wire I'm treating as the constant 12v is...
rmdl51
White_Shadow
rmdl51
Fullerton CA
kross
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
