Zune question
Open the software; connect your zune; select your zune from the menu on the far left; find the content you want to delete from the zune; right click the content; choose delete.
Ypu just need to tell the zune software what folders to monitor.
To add folders to the Zune Monitored Folders list:
Select Options , Add to Library (or press F3).
Click Add Folder and browse to a folder you want Zune to monitor.
Click OK. Zune will now include that folder in its continuous search for media on your PC.
Repeat steps 1-3 to add more folders for Zune to monitor.
If you dont plan on keeping everything on the zune and on your computer you should also set your zune to manual sync. The defaulty setting is auto sync and that means that it will sync whats on your computer to whats on your zune every time you connect your zune to your computer. When its set up like this it will delete from your zune what is no longer on your computer.
With the zune connected in the navigation area on the left, right-click the device and choose set up sync, and uncheck the automatic.
manual sync ftw
That way you don't stuff deleted when yuo are only interested in charging the battery
how do i get to the point where i can set it up for manuel sync
Also, if you have any days left on your free trial...I'll throw you some cash to use it
i havent even set it up yet..... is the free trial nice??? dose it start once i register my zune or when i visit the site for my free trial?
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
SethPhillips
I'sa Playa
SethPhillips
Northern Utah
SethPhillips
