Zed Audio Leviathan III 6 channel amplifier Mint condition Priced to sell
Vertex Audio
Pro Seller
Supporting Vendor
Zed Leviathan III
Mint condition, used very little. Still has film on plexi glass. Has been tested and is guaranteed to work upon arrival!
Specs:
Continuous Output Power into 2 ohm: 330w x 6
Continuous Output Power into 4 ohm: 190w x 6
Continuous Output Power into 6 ohm: 125w x 6
Continuous Output Power into 8 ohm: 100w x 6
Continuous Output Power 3 pairs of channels bridged into 4 ohm: 660w x 3 Channel pairs may be bridged independently
Continuous Output Power 2 channels bridged into 8 ohm: 380w x 3 Channel pairs may be bridged independently
Minimum Speaker Impedance: 2 ohm per channel
Minimum Speaker Impedance in Bridge Mode (2 channels): 4 ohm
Frequency Response at rated power into 4 ohms: 10Hz-30KHz -0.1dB
Input Voltage range for rated power into 4 ohms: 0.25 to 8.6 volt
Input Impedance at 2KHz: 47K ohm
Noise below rated output (30KHz limited) -100dB
Channel separation at 2KHz: >80dB
Damping Factor at 20Hz with 4 ohms: >80
Total Harmonic Distortion with 4 ohm: 0.05%
High Pass Crossovers (24dB/octave) Channels 1+2 and 3+4: 55Hz-4KHz
Low Pass Crossovers (24dB/octave) Channels 3+4: 55Hz to 4KHz
High Pass Crossovers (24dB/octave) Channels 5+6: 10Hz-105Hz May be used as a Sub Sonic Filter
Low Pass Crossovers (24dB/octave) Channels 5+6: 40Hz to 235Hz
Protection: Short Circuit, DC, Thermal
Power Source: 10-14.5v DC Negative Ground
Current Consumption with Sinewave at 4 ohms: 94A
Current Consumption with Music at 4 ohms: 18 to 28A
Idling Current:
Fuse rating with 4 ohm load: 30A-40A depending on usage
Fuse rating with 2 ohm load: 40A -80A depending on usage
Size W x H (247mmx55mm/9.7”x2.1”) x L: 410mm/16.14” Excludes connectors
Made in USA
$650 shipped. It is currently up on ebay. If a bid is received then this thread will be closed as SOLD.
FREE
The things I would do for this amp .....luckily Im starting shutdown at my job so I work 14 hr shifts the next 3 weeks so I will be buying one in the next couple....GLWS and awesome price!
We will be having a special this upcoming month on them while supplies last, so keep an eye out!
Item(s) for Sale: Zed Leviathan III
Specs:
Idling Current:
Made in USA
FREE
do tell sir, pm me if you can about this deal that is coming up
This amps has a wicked CO section. If I set my mid bass HPF at the HU can this amp run full 3 way active? And can it run all 6 channels off 4 RCA ins?
The amp can do all crossover points without using head unit. It has subsonic (which goes up to @ 42) for midbass, then you can go wherever you like on the other channels. I can't imagine how you would need any other crossover.
Any chance you can use anything in trade on this one?
I just want to be clear about the xovers. I run and old school deck head eclipse that doesnt have any xovers in it. With this amp, I can do three way active (tweets, mids, midbass)? I just want to make sure becasue I was told this amp has great high pass and low pass, but not bandpass.
Why do you want to run your hpf at the HU? Why not set it at the amp? Also I believe you can run all 6 channels with 4 rca ins, just use splitters.
Yes, this amp has a band pass! In the pictures you can see the options. Looks like the tweeter would be at 4k hz or lower.
Hope this helps!
Hope this helps!
That's how I run it now. Mid bass is cut off at 60 from the HU. That's the only way I can do it now. HU cuts off the bottom end of the mid bass, amps cover the rest.
Vertex Audio
Pro Seller
Supporting Vendor
Vertex Audio
Los Angeles
Vertex Audio
