Sold Zapco Anyone?
What're yee lookin' to get for that their amperfier? Got them there repherances? Got peectures?
//content.invisioncic.com/y282845/emoticons/needpics.gif.edd6d28e76618c28c46f343991bcced5.gif
Post email addys for pics.
Specs
Output Power 150 watts/ch @ 4W, 20Hz-20kHz
230 watts/ch @ 2W, 20Hz-20kHz
T.H.D. + Noise S/N Ratio >105dB
Dynamic Headroom .6dB @ 2 ohm load
Separation >70dB
Damping Factor >700 @ 4 ohms, 350 @ 2 ohms
Input Type Fully balanced differential REF GND
Input Sensitivity .25 - 5.0 Volts, variable
Maximum Input Level 10 Volts R.M.S.
Input Impedance 20K ohms
Crossover Range 30Hz - 720Hz
Crossover Slope Low Pass 12dB, 24dB/octave
Hi Pass 12dB/octave
Hi Pass T.H.D. + Noise Hi Pass Separation >85dB
Hi Pass S/N Ratio >120dB
Maximum Output Level 10 Volts R.M.S.
Power Requirements 60 Amperes max. @ 2 ohms
Fuse Rating Dual 20 Amperes - Automotive blade type
Minimum Load 2 ohms stereo
Idle Current 1.6 Amperes
Dimensions 16”L x 5-7/8”W x 2-1/2”H
usamps
usamps
around
usamps
Mike Mccabe
