zane check it out......
  • 2
The similarity between these and the Genesis ones only extends mildly to the case of the amplifier.
Have a look at the Specs of this for Example:
Poweramper AQ60x 4 channel
RMS POWER
120W x 2 @4ohms
60w x 4 @2ohms
30W x 4 @4ohms
Signal/Noise 105db
THD .025%
Frequency Response 15Hz- 100KHz
http://www.poweramper.com/classa_amp.html
Genesis "Four Channel"
http://www.genesis-ice.com/Home/Specifications/4_Channel_Spec/4_channel_spec.html
The comparrison was made between these two- as these would be the most likely "sisters" from each company.
As you can see, there are quite a few differences between the two.
The casing- is pretty close, however- if you look closely, you will notice the Genesis has more of a high lustre shine- as well as Gold contacts. The Poweramper has a more dull sheen, and has black covered contacts.
Poweramper QA60x
Interesting piece of information. It should be noted that Genesis is based in Great Brittain and Power Amper is based in Florida. While the specifications of both amps are phenominal, I still did not see any reference to this being a Genesis knock off- or vise-versa. It is still highly informative and a company to look into a little farther.
Thanks for the insight! //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
take it easy,
-zane
i used to rep a few lines and i think you would be suprised who makes what for who.....some are tall tales some arent..so i am not gonna say one way or the other but i can say there are far fewwer places that actually produce these toys than there are "manufactures"
These are decent budget subs. The box design isn’t bad at 5 cubes for these, but I’d drop it down just a little and raise port tuning up to 32...
And even then the Demons are a nice subwoofer. Heard a pair of those in the 10" locally Monday afternoon on around 1,200 watts and for a sealed...
HI all - I don't have a windows machine and thus can't use WINISD, so I've been playing with speakerboxlite.com Can someone cross-reference this...
audiolife
WhAt?
audiolife
indiana
audiolife
SPLBassJunkie
    May 21, 2024
    May 20, 2024
