Sold z0mg!!11!!! 4500W for $525 shipped....
tapout
I have 2 planet audios. 1 TT2250 and 1 vx2200d. Both have the same board and are strappable. I have all you need to strap them. Also, each comes with fuse block and 150 ANL fuse and bass knob. $270 shipped each. Paypal only.
http://ampguts.realmofexcursion.com/...Audio_VX2200D/
vx is sold. So is the TT. Thanks for looking
RMS Power into 4 Ohms 800 x 1
RMS Power into 2 Ohms 1500 x 1
RMS Power into 1 Ohm 2250 x 1
THD at 1 Watt, 4 ohm 0.30%
THD at Rated 0.50%
Signal to noise Ratio, below rated power output 100dB
Frequency Response, at 1 watt, 4 Ohm 15Hz to 150Hz (+/-3dB)
Frequency Response, at Rated Power, 4Ohm 20Hz to 250Hz
(+/-3dB)
Damping Factor at 20 Hz, 4 Ohm 400
Crossover: Low Pass 50Hz-150Hz, 24dB/Octave
Crossover: Subsonic (high Pass) 15Hz - 40Hz, 24dB/Octave
Bass Boost 0 + 18dB
Phase Control 0 to 180degrees
Input Sensitivity 100mV to 2V
Input Impendance 10K - Ohm
Line Output Impendance 100Ohm
Peak Current consumption, at rated power into 1 Ohm 175 Amperes
Dimensions (W x H x L) 11.34 x 2 1/4 x 19 9/16
Ran the TT at .7 with no problems. Just got the VX and ran it all day at 1ohm with no problems.
Bump for a solid amp. I have owned 3 of the TT2250's and a VX2200 as well. From what I could tell they all did rated RMS power up in the 2KW range. I had Memphis Mojo's beside them for reference.
TTT if you still have this baby in a week (hopefully not for you) I'll probably pick it up!!
what were you pushing with these amps?
I just had 1 on a type R. I bought an MT and decided to get the other amp and strap them then decided against that as well. I would just rather have one amp instead of strapping.
tapout
tapout
Ga
tapout
AJ (ACE)
    Jun 24, 2026
AJ (ACE)
    Jun 24, 2026
