Sold z0mg!!11!!! 4500W for $525 shipped....
tapout
I have 2 planet audios. 1 TT2250 and 1 vx2200d. Both have the same board and are strappable. I have all you need to strap them. Also, each comes with fuse block and 150 ANL fuse and bass knob. $270 shipped each. Paypal only.
http://ampguts.realmofexcursion.com/...Audio_VX2200D/
vx is sold. So is the TT. Thanks for looking
RMS Power into 4 Ohms 800 x 1
RMS Power into 2 Ohms 1500 x 1
RMS Power into 1 Ohm 2250 x 1
THD at 1 Watt, 4 ohm 0.30%
THD at Rated 0.50%
Signal to noise Ratio, below rated power output 100dB
Frequency Response, at 1 watt, 4 Ohm 15Hz to 150Hz (+/-3dB)
Frequency Response, at Rated Power, 4Ohm 20Hz to 250Hz
(+/-3dB)
Damping Factor at 20 Hz, 4 Ohm 400
Crossover: Low Pass 50Hz-150Hz, 24dB/Octave
Crossover: Subsonic (high Pass) 15Hz - 40Hz, 24dB/Octave
Bass Boost 0 + 18dB
Phase Control 0 to 180degrees
Input Sensitivity 100mV to 2V
Input Impendance 10K - Ohm
Line Output Impendance 100Ohm
Peak Current consumption, at rated power into 1 Ohm 175 Amperes
Dimensions (W x H x L) 11.34 x 2 1/4 x 19 9/16
Ran the TT at .7 with no problems. Just got the VX and ran it all day at 1ohm with no problems.
It says max, however this is one of the few amps that actually does the max stated. All benchsheets agree. This is not the benchsheet to my amp. I bought mine used without it..
tapout
tapout
Ga
tapout
