The HACKER
custom chaos
Thought maybe it would get some attention...
There Will Be Two Subs just dont know which one. (Sorry again edited)
HDC3 Specs
Woofer Size 15″
Fs 38 Hz
Sd 89m M2
Krm 12.686 mOhm
Erm 0.875
Kxm 144.352 mH
Exm 0.628
Vas 70.421 Ltr
Cms 62.609 uM/N
Mmd 253.635 g
Mms 268.902 g
BL 22.39 TM
Qms 7.405
Qes 0.444
Qts 0.419
Sensitivity 1W/1m 91.532 dB
Magnet Diameter 8.7″
Magnet Weight 340 oz
Coil Diameter 3.0″
Coil Length 2.135″
Useable Throw 3.0″
Continuous Power 1000 W
Music Peak Power 2000 W
Mounting Depth 8.875″
Circle Cutout 14.0625″
RE XXX 12 Specs
12"
Mounting Depth - 12.75"
Mounting Hole Diameter - 11.5"
Overall Diameter - 13"
Bolt Hole Circle - 12.25"
Motor Width - 10.5"
Motor Depth - 5"
Basket Depth - 7.75"
Displacement - 0.24 cu. ft.
Weight - 72 lbs
Electrical Q Value -Qes: 0.46
Mechanical Q Value -Qms: 3.29
Total Speaker Q Value -Qts: 0.404
Free Air Resonance -Fs: 21.00 Hz
Equivalent Compliance -Vas: 74.0 liters
One-Way, Linear Excursion -Xmax: 54 mm
Efficiency -SPL 1W/1m: 83.76 dB SPL
Effective Piston Area -Sd: 480 cm^2
DC Resistance -Re: 4.2 ohm
Nominal Impedance -Znom: Dual 2 ohm
Thermal Power Handling -Pe: 2000 W
Force Factor -Bl: 18.16
Either Sub will be firing to the trunk lid in a ported box built to reccomended specs. Amp AQ3500 (3500 rms) Not for competition for music. Question is what would be the best musical wise in comparison of the specs given. 36hz will be port tuning.
HDC3 Specs
Woofer Size 15″
Fs 38 Hz
Sd 89m M2
Krm 12.686 mOhm
Erm 0.875
Kxm 144.352 mH
Exm 0.628
Vas 70.421 Ltr
Cms 62.609 uM/N
Mmd 253.635 g
Mms 268.902 g
BL 22.39 TM
Qms 7.405
Qes 0.444
Qts 0.419
Coil Diameter 3.0″
Coil Length 2.135″
Useable Throw 3.0″
RE XXX 12 Specs
12"
Motor Width - 10.5"
Motor Depth - 5"
Weight - 72 lbs
