Yet to find a ground in the rear
See if you can use one of the rear seat bolts or even a seat belt bolt. They will have a good, solid platform to hold a tight bolt.
Just remember to sand the paint down to bare metal. After you make your connection, spray a little primer on it to prevent rusting.
---------- Post added at 03:54 PM ---------- Previous post was at 03:54 PM ----------
dam....6sec late...lol
how should i test which bolt, and if it even has a good power current going through it?
---------- Post added at 03:55 PM ---------- Previous post was at 03:55 PM ----------
why don't you want to drill?
If i have to re-sell the car later i don't want that there..
If it is bolted to the body, it will work just fine. As was said though, if you can, run it straight to the battery.
---------- Post added at 03:57 PM ---------- Previous post was at 03:56 PM ----------
If it is under the interior trim, it will most likely never be noticed.
Well i don't have enough wire to go all the way back up to the battery, as i would like to do that it sounds much easier!
As long as the chassis is grounded well to the battery, you can ground to the chassis in back using a seat belt bolt or seat bolt and you'll be fine. The electrons will return through the chassis back to the battery.
Tek18
Tek18
KY
Kangaroux
