XXX15 box
Build the huge port. **** that sub has a high xmax. Makes for a quality one I suppose though, right //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Good luck, and post a worklog!
Build the huge port. **** that sub has a high xmax. Makes for a quality one I suppose though, right //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gifGood luck, and post a worklog!
Alright ill try it. But with this box, im going to have to put the sub on top of the box. The one spot wheres there no port. IS that ok?
And also, that port makes my box tiny, and thats about as big as i can go that will fit in my trunk. So what should i do?
well you have it set tuned to 28 hz. the lower the tuning the longer the port, and i will say it again. lots of port area, makes em go boom boom
Ok well iv been working on this design now for alittle bit. With some of the desings iv already posted, the box is volume is huge. Like all i did was take the external demenions, to find the net volume it got about 9ft^3.
http://www.subwoofertools.com/forum/ported-box.asp?Ew=36&Eh=17&Dia=9&Xmax=32&Vd=.19&NumW=1&Vb=5.0&Fb=28&Qts=&Vas=&Fs=&CE=0
With this plan, i got 9.47ft^3. I put in 5ft^3 for the net but end up with 9. So now i am completly confused.
The biggest demntions i can go in my truck in 36 wide, 36 deep and 17 tall.
Snozzer
Snozzer
Michigan
iamamp3pimp
Mike Mccabe
