XXX dual 2 wiring
blckmounty
I just got my XXX15 today, and i am a little confused o how to wire it. It is a dual 2, and i will be running it off of a hifonics bx1500d at a 1 ohm load. I want to wire it in parallel, but this is were i get confused. I am looking at the resonant engineering website, and it shows to have the positive wire go from positive terminal to the other positive terminal, and the negatvie wire to go to negative terminal, to negative terminal. How do i go about doing this? should i attach the wires to the first terminal, and then squeeze another wire into it to go to the other terminal? Or am i supposed to feed it trhough on terminal and attach it to the next? :stuck:
no, attach them, don't feed it through. You connect the positive on one coil to the positive on the other coil, and then run a wire to the sub, and do the same thing with the negative. John
So i should connect the positive terminal to the other postitive terminal with a piece of wire, and then run a wire from the amp into one of the terminals wiht the other wire already in it?( the other wire is the one going ot the other terminal) then vice versa for the negative
blckmounty
blckmounty
jersey
desi_daru
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
