Xxx Box Help
darren700
got bu/\/\p?
ok, im desining a box for a 12" XXX, my maximum dimensions are 14" x 33" x 19", the recomended box size is 2.1 cubic feet for the sub. i want to tune at 28hz. one thing im confused about is how to port it, i was orginally planning to slot port it, however it seems that the box would take up alot more room if i did that. what confuses me is how come if i were to use a 4" diameter tube as a port, it would only have to be 17.64" long, according to this: Port Size Calculation
why is it so much smaller when using a round port than a slotted port? is there any advantage to using each? help is much needed, as the gained trunk space would help alot if i could build a smaller box because of porting with a tube..
thanks
ok, im desining a box for a 12" XXX, my maximum dimensions are 14" x 33" x 19", the recomended box size is 2.1 cubic feet for the sub. i want to tune at 28hz. one thing im confused about is how to port it, i was orginally planning to slot port it, however it seems that the box would take up alot more room if i did that. what confuses me is how come if i were to use a 4" diameter tube as a port, it would only have to be 17.64" long, according to this: Port Size Calculation why is it so much smaller when using a round port than a slotted port? is there any advantage to using each? help is much needed, as the gained trunk space would help alot if i could build a smaller box because of porting with a tube..
thanks
the sloted port was prolly double the size therefore needing twice the length //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif. If you did aeros, Id go with 2 4" ones.
why do you say use two ports? because it allows the air to flow more freely? if i were to use 2 4" aero ports, the required length would be 38.21", is that the length for each port? or a combination of the two? that would pose a problem as the maximum length you can order aero ports at is 17"... this seems pretty **** confusing...
with the xxx you will need two 4" ports if not more because of the amount of air it will move. and that length is a combination of the two they would both be half that.
darren700
got bu/\/\p?
darren700
Windsor, Ontario, Canada
darren700
